1 - 3 of 3 Posts
Usually amps have a minimum impedance (or ohms) rating. This means that they can power subs of this ohm rating or higher. So there shouldn't be any problems hooking an 8 ohm sub to a 4 ohm amp. There would be problems, however, if you did the reverse.
1 - 3 of 3 Posts
