Going to Capitol on 10/1. Not this FRiday but next.
Intarnet > Yu0.Originally posted by petsnowman
Router messed up only post 1 line or times out.
www.ogracing.comOriginally posted by petsnowman
Going to need a helmet.
Yeah, Jerry, I thought the time was OK seeing as I had all that audio system weight and the 19's on it.ShadowGT-S said:Wow thats a pretty good time Bill!! lol Mike you better watch out!! I might show up next week at Capitol.
I would if i could but i cant. Get off next friday. Wach me run 13.4.Originally posted by BrianGTS
bill is teh OLD! :chuckles: Bill, may I suggest you use the nitrous from the end of second gear on instead of off the line? That may help you. Definetly good times considering the 19s and the 3 million LBS of stereo thats in the car.
Mike, you suck. Go to capitol tonight. Im off today.
just about 2ish it starts to spool. Never really payed attention to at what rpm it hits full spool at. Right now i basically made a spring to make more tension on the WGA which in essence acts as my own little boost controller. I am pushing 17psi as opposed to the stock 13psi. I just need to buy a stage 1 PCM because the stock PCM recognizes the overboost and corrects the problem after about 50-100 miles. So i have to reset the computer again to hit the high boost numbers.Originally posted by 2000 XYR
I didn't realize that I guess. I knew they were a little faster than a WRX though, but I figured low 14's. What RPM does the turbo spool up fully?
Nicely done. The weather was nice tonight. You better go with me next week. I guess i should birng a helmet just in case.Originally posted by ShadowGT-S
60'... 2.200
1/4...14.739
I was trying not to use the nitrous until 2nd gear, but I had a little case of the nerves, and I'd forget and floor it on the launch which triggers the WOT switch.Originally posted by BrianGTS
you can put DR's on your stock rims bill. they should work fineOriginally posted by skreemin_trdgts
I was going to run with my stock rims & tires, but I was thinking I'd get better traction with the wider contact patch on the 19's and being as they are a little heavier. I want to get some slicks for the front. Anybody know who sells them around here and what size would be the best fit for the celica?
http://www.newcelica.org/forums/showthread.php?s=&threadid=148398Originally posted by skreemin_trdgts
