1 - 12 of 12 Posts
the first time i start my car after i fill up my tank, my car wont turn over. but the second try it starts up fine. this problem only happens everytime when i fill up. this started to happen after i did my auto to 6speed swap. i have a pcf in my car right now. does anyone know what might be the problem?
Before you turn on the car, try just turning the key so all your electronics on on, and give it a couple seconds before you try the start. Sometimes it works with these types of problem, it does someting to the fuel injectors.
Marc
Couple ideas:
Gas cap tight?
When you fill up, do you top it off? If so, cut it out. You might have saturated your charcoal canister. I think that was messing with my idle for a while. Yours might be the same, but at start up.
Zettai Unmei Mokushiroku
Has this happened all the time since the swap or just recently? It could be an incorrect hose hookup on the EVAP system (charcoal canister and gas tank).
Discussion Starter #5
Marc
i'll try that next time get gas.
Originally posted by DaileyDog
Couple ideas:
Gas cap tight?
i wait 3 clicks for gas cap. and i dont top off.. cause u heard when u do that u are just wasting $ because it sucks gas back in the hose.
yeah its been happening ever since i got the swap done. how do i check if its the EVAP?
You may want to check if the hoses connected to airbox is connected correctly (if you have no idea take a look at other people's hoses). A buddie of mine had this problem whenever he fill up the tank, took forever before a Toyota specialist figure things out.
:werd: & :werd:
I had this happen to my car alot for a while. It was a disconnected hose.
This just happened to me today. I just have an AEM intake in the car. Thanks for the information guys i'm going to check to see if it is the hole that is loose or something.
It used to happen to my car. It turned out that a valve in the gas tank that controls venting pressure was bad. Have you been topping off your tank? The fuel can splash around on this valve/filter and cause a similar problem. My check engine light came on and it took them 6 tries to figure out what the problem was.
I had this happen to me but it was when I had some work done to the car and the mechanic swapped the 2 wires. The one that should have been connected wasnt and the one that shouldnt have been connected was. So I just switched them back and everything was ok. I am being lazy and dont want to go look under the hood but I believe one plug was blue and one was black...either way the blue one should not be hooked up and the black one should...they look the same and they can both connect to the same place despite the color difference. So check those out.
Discussion Starter #12
after my tranny swap.. cause i ran my automatic ecu with the 6-speed and it was running funny so i got a pfc.
1 - 12 of 12 Posts
