FrostsCelicaGTS said:
when was the last time you change ur oil did you change it at exactly 3,000?
Um, usually I try to change it every 3000 miles but since I am running synthetic I should be able to run at least 5000 before I technically need to change my oil but I do it every 3000 anyways, normall. I was a little late this time like 750 miles over but that is not really a big deal.
QTRMLR_1 said:
never heard of purolator....how much did it cost?
my car always runs a little better after an oil change.
Purolator has been around for a long time and too my knowledge were one of the first companies to develop oil and air filters. The filter itself cost me $3.98. As far as the car running better after an oil change, mine usually runs better as well, except for this time.
monkeywrench said:
Is the oil light on? That's the "gauge" that Toyota gave us.
Um, I don't really know whether to take your comment jokingly, as sarcasm or what LOL, but I assure you my oil light is not on. If it was I would shut the car off immediately and sure as hell would not be driving it. On top of that even if the oil light was on it would not make any difference. I do not even know why they waste the effort putting those things in cars because they are pointless. By the time the oil light came on, if it was really that low on oil, the damage would have been done anyways. I guess it would keep you from doing more damage but 9 times out of 10 if that light comes on then you can almost bet you have damaged your motor somehow.
Anyways keep the ideas of the problem flowing because it is still acting sluggish and I have yet to figure out the problem. Perhaps I should take it in to a mechanic or just keed driving the damn thing. I know it has oil in it, plenty, i just checked it when I got home. I let it sit for awhile and then went outside and checked it and it is actually reading a little lower than it should like maybe an 8th of an inch below the fill line. I haven't figured that out either because with roughly 4 quarts in it then it should be right on the fill line. I have also checked for leaks and cannot find one at all. I give up LOL. If anybody has any ideas please respond. Thanks for all the help guys.
