I just recently did a tune up on my car at 53k miles.
New plugs, GM Top engine cleaner, cleaned MAFS, cleaned IAC and throttle bodies, checked/cleaned PCV, cleaned PCV lines and ran a can of Gumout TB and Manifold Cleaner.
The PCV lines were actually very clean, as was the throttle body and IAC. However, the car still starts somewhat hard and runs very poorly when cold. When I say starts hard, the car would always catch at about the third revolution of cranking, and now it seems to take 5-6. At WOT at high rpms, I have seen and people report that I blow some smoke. I believe the smoke is fuel related because I would think that if it were a ring issue, I would see evidence in the PCV system. This weekend I was barely able to pull away from an old Formula 350 automatic in 3rd gear.
I am now suspecting the O2 sensor or an exhaust leak. There is definitely an exhaust leak going on, and it may be from the flange at the back of the header. I'm wondering if a leak before the O2 sensor could cause my problems? I was considering replacing the front O2 sensor and any gaskets in the exhaust system.
Any thoughts on the coils or injectors? The plugs had a very uniform appearance, so I don't suspect the injectors much. They all indicated a lean condition, but I have a CAI so I expected that.
