Raymund said:
It's sad to see everyone so concerned with 'straight line' performance. Taking weight off the car will lower the cars inertia. This will yeild faster transitions, better cornering speeds and improve braking distance. Since the hood is at one of the high points on a car, it will have the greatest effect given the same amount of weight removed else where below it.
dang you! you beat me too it!!!
Reducing weight is a great mod you can do to your car, it will help your cornering, braking, and acceleration. granted 20lbs might not seem much right now, but add up the weight you'll save with lightweight wheels and other lightweight parts and it all adds up.
Take for example my s2000, the stock exhaust weights 50 lbs! the one I will be moving to is 12lbs and gains 7-9rwhp. That's 38 lbs saved, which equated to the same as adding 3hp and I also get 8hp from the free flow exhaust. Then say I decide to go to a carbon fiber hood and it save me 15. That's over 50lbs saved right there. Now my car accelerates quicker, brakes better, carries more speed into and out of a turn, has much quicker transitional response, and is a little bit easier on the tires.
Less weight = going faster! Here's a weight reduction for you, this s2000 is only 2300lbs. and yes that wing on the back is functional and no it doens't add much weight, it's fully CF so it's like 2-4lbs
and yes it does move! It kicked butt in OTC (open track challenge) this yr (2nd place in Unlimited 3), here's a link to the thread about Rylans car.
http://www.s2ki.com/forums/showthread.php?s=&threadid=116070
I estimate a 500-lb weight reduction in a car this size to be akin to gaining 40-45hp or more importantly, a second off one's 1/4-mile time which in most cases, would result in one nipping at low 13's and perhaps even high 12's, depending on how the weight loss affects traction off the line.
Formula used is 1-lb = .0021 seconds in 1/4-mile.
^^^ from the thread linked above.
Karim
