Just as an FYI - with the SF kit all you have to do to be smog legal when you get inspected is to take the charge pipes from the intercooler to intake off, put the stock intake box back into place, put the SS ECU to all 10s, put the vacuumn lines back to normal, and run the fuel hose from the supply line to the rail instead of the FMU and disconnect the power line to the FMU and you should be able to pass smog no prob.tacn it said:does anyone here know of a turbo for the gt that is californa legal?(with carb# ,passes smog...)any info would help greatly, thanks
