I have my hub stands for sale. (I have the tooling to make another set)
These were made by me this year. 1/4” steel for less flex and they sit on two roller balls so you can check camber and castor without having to bounce or roll the car to settle it. You can turn the wheels while on the stands so double as turn plates.
I use strings around the car to create a box to set the toe very simple and accurate. The toe bar is adjustable so i could take into account the different track widths front to back.
Scale is in mm for toe setting.
Will also fit miata so any 100x5 or 100x4 that has max 45mm center hole.
I use them at the track to adjust alignment in an hour. Also easier to adjust r height or corner weights.
Located in Fresno California. Probably too heavy to ship but I can deliver around a 100 mile. I am also at buttonwillow raceway oct 4-5 if that helps.
i could not find any to buy less than $1000 with toe bars that fitted a celica so had to make them.
Sell for $500.
The box under the rear one is just to level the floor of my garage. Its because my garage slopes.
zip code is 93726
Sell for $500.
zip code is 93726
