21 - 27 of 27 Posts
Sorry about the rubber gaskets you told me are on the intake manifold, are they between the manifold and the cylinder head?
Best Regards
Correct!
Gasket looks like that but may be a different color such as green or blue.
Ok, maybe i can get it in Toyota Portugal, is a litle expensive, but not to much in rubber materials
It's the same gasket that almost every 1ZZ uses so it should be readily available almost anywhere but I can't comment on the cost.
Discussion Starter · #25 ·
costs must always be in mind, without sacrificing quality (between us, without making a fuss, as it is not adequate). I recently changed the Oil Pump to my Corolla 2.0D (367,000km), the oil pump on Toyota Portugal, it cost 300€, I got an AISIN...., for 60€, online. We have to search and explore, the oil pump is original, Aisin.
Absolutely, in the case of the gasket if it's bad even a cheap part will be better but may not last as long as a good part.
Sent from my SM-G892U using Tapatalk
21 - 27 of 27 Posts
