I changed my lift bolts a few weeks back and after I changed them everything was fine. Week later, tried hitting lift and rev limiter kicked in at 7k. So I opened the hood and noticed I had oil around the valve gasket so I unbolted and reseated valve cover and was able to hit lift again. Next weekend again rev limiter kicked in at 7k so I ordered a new valve gasket and installed that plus using torque wrench retightened all bolts (including lift bolts) and was able to hit lift again. This weekend again I have a limiter kicks in at 7k.
So any suggestions on what I'm doing wrong. I disconnect the battery everytime I've done this to reinstall/retighten (if that has anything to do with it).
I'm at a lost for what to do so some help would be appreciated.
Edit: forgot to mention that the car is fully warmed at the time also 60k miles on the engine.
