i have had my 2001 GT celica MT for 3 months now. i have already had to replace the tranny, and the check engine light went on for the second time this morning. the first time the light when on i was getting evap codes, i brought it to the shop, they charged me $70 just to turn off the light. apparently nothing was wrong.
is there anyway to reset the engine light without the handheld diagnostics computer? i am really not interested in paying another $70 to have a light turned off
suggestions?
thanks
suggestions?
thanks
disconnecting the battery for a few minutes will turn off the light but it will continue to come back on until the problem is fixed.
i had this reoccuring issue for like 3 months, i went through an engine replacement, idle speed control valve replacement and some other minor work. Eventually got to the bottom of the problem...it was a faulty wiring loom. Got that loom replaced and havnt had the light turn on since.
Are you close to Indiana, PA, If you are you can drive up here and let me have a look at your car. I have my own code reader.
