Yea, I know. Originally I didn't want them like that, but after an earlier attempt at laying the graphics below that body line, for some reason it didn't quite look right to me when the passenger side was done.
I started over from scratch, using masking tape to create my lines, and played around with it a little, I let the lines flare up at the rear, and it seemed to work for me. I cut the graphics again, and this time around, I liked it better.
In actuallity, it's best if the bottom edge of the graphic were to flare down at the back (where it curves around the wheel arch and out to the taillights) but again, I taped the lines out and I thought it looked gaudy as hell.
It's one of those things where it comes down to personal preference. I didn't like crossing the body lines either, most designers consider it sacrilege, but this achieves the best look from the profile for my tastes.
It's mostly due to the fact that that perticular body line has an up/down curve to it from front to back. it's very subtle, and because the graphics are mylar, you can't get them to fit those linear curves as easily as vinyl or masking tape does. the line had to pass under the side mirror and follow that line, but it's not perfectly straight, it's actually a subtle arch, and mylar can't flex along it's edge axis, not without getting wrinkled. And that's the downside to this stuff, it won't always conform to the curves the way vinyl, tape or paint can.
If I were to do it over again, I'd take those curves into account when cutting my templates, so the graphics wouldn't need to wrap over at the end, the cuts would incorporate the curve in the first place. maintaining that curve when you transfer tape-lines to paper is tough to do as well. Hindsight is 20/20 after all. Still, overall, I'm pleased with the end result.
I guess the other reason it works for me is the fact that it's chrome, the parts of the graphic that wrap around the curve and face up reflect the sky, those that face down reflect the ground, and those that face out will reflect what's around the car. So in incorporating the curves, you get a nice amount of the environment reflected in the stripes. It's sort of hard to describe, but it actually looks good that way in person. midway down the stripe, the graphic just begins to wrap over, the further back you go the more it wraps over, until, at the end it's about half under the line, and half over the line. It actually looks really nice on a clear, sunny day.
The photos don't begin to do justice to it.
I can always do it over again if I choose to, but right now, I'm pretty satisfied.
