Okay,
So I've searched an found a lot of info and am pretty sure as to what to do. I bought a H/U with 3 RCA jacks and am going to run them to my 5 channel amp. Then, I run new speaker wires from the amp to all the speakers and subs.
I'm not sure though on a couple of things:
1. How do I run the new wires to all of the existing speakers in the fronts? Should I cut out the stock subs and wire the speaker and tweeter in series since I'm using new subs?
2. The connection in the back of my H/U has a ton of wires. Do I hard wire everything except the speaker wires together with stock wires by pulling them out of the stock plug and soldering/crimping?
3. Do I use the ground wire comming out of the H/U and ground it to one of the screws or is there a wire to splice it to from the stock plug?
Thanks for the help in advance. I am very new to wiring and this is my first system install, so yeah...
-Christopher
-Christopher
