So my right passenger strut makes this popping clunking bad sound. it was pretty subtle when it started but then after i jacked the car up for an oil change the clunking got worse. It only happens at low speeds below 30mph? i want to say. also turning the wheel doesn't affect the clunking. Anyways i just jacked it up to take pictures and it started doing it more often
I did research and the most common problems seemed to be either the top middle bolt or the endlinks. I checked the top bolt which was nice and tight. When i checked the endlinks, the top one didn't tighten. It just kept spinning. Think that may be the problem. The bottom of the endlink is fine.
Is it my endlink? blown strut? some other bolt that's loose? HELP PLEASE
check the pics:
top:
bottom:
side view:
check the pics:
top:
bottom:
side view:
