1 - 4 of 4 Posts
Hi all. I need to replace the steel brake line that runs from the Clutch master cylinder along the fuse box, and over to the Slace Cylinder Flex line.
Does anyone have any tips on how to undo this line from the Master cylinder without actually pulling the master and the brake booster? It's a very tight spot!
I don't want to have to pull the brake booster and master cylinder if I don't have to.
FYI, it's an 2002 Celica GT
Thanks in advance all!
Wrong :) I got it off. It took a lot of patience, and a few scraped knuckles. I used a long 10 MM wrench, and was able to turn it 1/3 turn at a time until it came our. The trick is flipping the wrench over with each turn to get the different angles.
1 - 4 of 4 Posts
