1 - 3 of 3 Posts
So my buddy owns a 02 Type-S, I notice he does use his clutch ALOT when rolling from a stop, or on a hill, ect.. anyhow his problem is..
When you push the clutch in, it sticks. Stays engaged, doesnt push back out like the pedal should. It just pushes in, you have to pull it back out with your hand... I popped the hood and had him push and pull the clutch pedal for me so i could listen/watch... It makes a squishy type sound when pressed in.
I checked the clutch fluid, its fine.
fluid might be fine but the seals in the master cylinder might be bad so fliud is getting by them. i have the same problem in my all-trac. i need to rebuild the master cylinder
1 - 3 of 3 Posts
