1 - 8 of 8 Posts
my celica has been giving me some problems that nobody can seem to fix.when i start off to go my car hesitates alittle sometimes like it wants to stall out.my car is an automatic.iwas told it was due to the cold air intake and that as long as i have one its not gonna go away.
check your plugs, you might be sucking too much air into the engine also..
My car hesitates the same way, and I have an automatic with cold air intake too. I let it sit a minute after starting it and I dont have any problems. If I drive it right after starting it, it will hesitate and sometimes stall.
xCraZyEddiEx said:
Try Reseting The Ecu
So, no hesitation with OEM airbox? Over 50,000 K on car yet? Also, did the problem start immediately after you installed the intake or have you had the intake for a while, but the problem only recently?
Have you done the Blue Bomber mod (search for "Perfect CAI" if not), checked for vaccum leaks, checked filter to ensure it is clean/new, checked MAFS (cleaned, or if all else fails, replaced), checked O2 sensors, etc? Check all of these things first.
1 - 8 of 8 Posts
