1 - 19 of 19 Posts
I'm close to hitting 95k miles, just wondering what are common problems with high-milage celicas and what should i be looking out for?
some problems i had:
-wheel bearing had to be replaced at 80k
-Shifter cable had to be replaced at 70k
thanks
pinoyracer said:
Only problems I had when my car hit the 90k was a bad MAF sensor and a dead battery.
your lucky, I got the dead batterie at 50k
+ lift bolt at 53k on the car but only 30k on the motor and they don't want to repair it stupid dealer, will cost 700$ damm !
lets see.... i got my car when it had 50k.
50k - broken lift bolt
57k - bad 2nd syncro
60k - shifter cable snapped
70k - bad 3rd syncro
I hope there won't be any more problems.
~ 30 K a/c compressor clutch died; belt tensioner began to squeal after rain
~50 K MAF sensor and O2 not working as well as they could; orginal brake pads finally needed replacing
That's it. Other than the a/c dying an early death, she's been as reliable as my other two previous gen Celicas (knocking on wood :chuckles: ).
nice info :thumbup:
How much did it cost to fix the syncros?
Royalcelica00 said:
70k broken water pump
how do u know that ull need a new wheel bearing?
You will hear a fast tapping nosie coming from your wheel. It sounded like a helicopter was following me hehe.
2002 GT, no problems really, dead battery at 70k. That is it for me.
thanks
What are symptons that you need to replace your shifter cable? I notice at time when I'm shifting, it doesn't want to go into gear or have to force it more than normal.
How much to replace syncros and what are symptons for needing replacement?
I called the dealership just this past tuesday and I told him symptons that I was noticing with my car. My car will tend to lose engine performance in gears and in first gear it will make a metallic chatter sound; they told me that it could be numerous things, but he did inform me it could be parts of clutch, timing chain, other things. I'm taking my car in for diagnostics tomorrow to find out exactly what the problem might be, but do you think what he told me is a fair analysis?
Thanks,
Hector
Purchased at 37k miles right away- bad 3rd gear syncro
38k miles- noticied that it was burning oil bad
38k miles- both lift bolts were changed, both were in good condition.
41k miles- spun rod bearing, got engine rebuilt but is still running like crap
41k miles- looking for another car
I think that I bought a lemon :thumbdown
12k-100k
nothing wrong...except for bad 02 sensor at 30k, other then that...engine runs good, and strong....oil changed every 2-3k, maf cleaned every 10k, new spark plugs every 15k, new tranny fluid every 25k...i think im missing something else too but yeah...
Bought @ 35K last yr... now @ 75K... new cyl head due to lift bolts.. found right after I joined this board :thumbup: I think I'm looking @ wheel bearings soon. Think I'm starting to hear some hum around 35-45 mph. Yep, still on original clutch and brakes... which I have new rotors & pads to go on... probably do it all @ 90K.. if the bearing holds up.
From Toyota experience... not necessarily Celica... common high mileage Toyota items can include:
*clutch (although, both my last Camrys went over 200K on the originals)
*transmission (ditto)
*brakes/calipers/rotors/slave cylinders(on drums)
*alternator
*exhaust (which will include cat/resonator)
*shocks
*Clutch Slave & Master cylinders
*water pump
*Power door locks/power windows... especially driver's side.. from repetitive door opening/closing breaking the wires between the door & frame
*CV joints (clicking)
*lightbulbs... not necessarily blowing.. but the lead contacts melt down.. particularly Tail/Brake
*steering wheel horn ring wearing out (uses brushes like the alternator)
*belt pulleys
*Fuel gauge sender (they wear down)
'00 GT with 102k, bought at certified used at 60k. Only thing I've had to replace is a bad VSV and that notorious belt tensioner. Other than that just regular maintenance and the occasional MAF cleaning.
2000 GT-S 80k miles
Belt tensioner - sucks
synchros -grinding
clutch - replaced with synchros
lift bolts - broken
MAF - bad
Sunroof (peeling)
Head light (condesation)
Rear hatch gas shock - lost pressure
Most of mine I took care of while under the warranty period.
1 - 19 of 19 Posts
