1 - 15 of 15 Posts
The scope of this thread is to serve as a table of contents of common performance modification topics, questions, reviews, install notes and other relevant topics.
Below you will see topics in Bold Text followed by links to useful information on them. All new topics will be added by edits to the main table of contents, so check for changes and new topics frequently.
Common Bolt-On Engine Performance Modifications
Cold air and short ram intakes
- Blue Bomber (BB) Mod for intakes
http://www.newcelica.org/forums/showthread.php?t=112681
http://www.newcelica.org/forums/showthread.php?t=205453
Airbox flapper delete
http://www.newcelica.org/forums/showthread.php?t=347192
Exhaust systems
- Common GT-S axle-back exhaust comparison by Turbo magazine
http://www.turbomagazine.com/tech/0209tur_toyota_celica_exhausts_test/
- Other GT-S exhausts
http://www.newcelica.org/forums/showthread.php?t=245404
- GT axle-back comparisons
http://www.newcelica.org/forums/showthread.php?t=245403
- Sound clip database
http://www.newcelica.org/forums/showthread.php?t=245405
- NOTE: TRD Kazuma was the only cat-back exhaust ever produced. All other are axle-back (Greddy is often advertized as a cat-back).
Exhaust headers and catalytic converters
http://www.newcelica.org/forums/showthread.php?t=204266
- "Race" headers
http://www.newcelica.org/forums/showthread.php?t=237200
http://www.newcelica.org/forums/showthread.php?t=230849
http://www.newcelica.org/forums/showthread.php?t=229905
http://www.newcelica.org/forums/showthread.php?t=230773
- Cat deletion, O2 simulation and plug defoulers
http://www.newcelica.org/forums/showthread.php?t=211552
http://www.newcelica.org/forums/showthread.php?s=&threadid=15130
- Header ID and special considerations for 2003-05 model cars
http://www.newcelica.org/forums/showthread.php?t=205642
http://www.newcelica.org/forums/showthread.php?t=205889
- Ceramic insulation coating
http://www.newcelica.org/forums/showthread.php?t=196963
- Exhaust manifold studs
http://www.newcelica.org/forums/showthread.php?t=213279
http://www.newcelica.org/forums/showthread.php?t=192388
- Header install guide
http://www.newcelica.org/forums/showthread.php?t=205898
Underdrive pulleys & undampened pulleys
http://www.newcelica.org/forums/showthread.php?t=110791
http://www.newcelica.org/forums/showthread.php?t=111107
http://www.newcelica.org/forums/showthread.php?t=111206
http://www.newcelica.org/forums/showthread.php?t=21926
http://www.newcelica.org/forums/showthread.php?t=119577
Scam/eBay Mods that don't work
- The Tornado
http://www.newcelica.org/forums/showthread.php?t=75366
- Fuel line magnets
http://www.newcelica.org/forums/showthread.php?t=10916
- Air temperature sensor resistor
Other External Engine Modifications
Lubrication system
- Oil coolers
http://www.newcelica.org/forums/showthread.php?t=133494
http://www.newcelica.org/forums/sho....newcelica.org/forums/showthread.php?t=194155
- Oil pans
http://www.newcelica.org/forums/showthread.php?t=177967
Cooling system
- Radiators
http://www.newcelica.org/forums/showthread.php?t=202486
- Low temperature thermostats
http://www.newcelica.org/forums/showthread.php?t=210420
http://www.newcelica.org/forums/showthread.php?t=184035
Fuel system
- Fuel pumps
http://www.newcelica.org/forums/showthread.php?t=189412
http://monkeywrenchracing.com/mwr_fuel_system.html
- Stock vs. Walbro 255 lph
http://www.newcelica.org/forums/showthread.php?t=190656
- Fuel injectors
Ignition system
- Spark plugs
http://www.newcelica.org/forums/showthread.php?p=3176302
- Ignition coils
http://www.newcelica.org/forums/showthread.php?t=151267
http://www.newcelica.org/forums/showthread.php?t=149615
Belt tensioner/drive belt noise and part revision
http://www.radphys.com/TSB_Belt_Tensioner.pdf
http://www.newcelica.org/forums/showthread.php?t=158699
Removal of air conditioning compressor
http://newcelica.org/forums/showthread.php?t=190815
Internal Engine Modifications
Camshafts
http://www.newcelica.org/forums/showthread.php?t=209845
http://www.newcelica.org/forums/showthread.php?t=206868
Valves, springs and retainers
http://www.newcelica.org/forums/showthread.php?t=188039
http://www.newcelica.org/forums/showthread.php?t=212987
http://www.newcelica.org/forums/showthread.php?t=206435
Cylinder head porting & polishing
http://www.newcelica.org/forums/showthread.php?p=3670976
http://sportcompactcarweb.com/tech/0009scc_cylinder_head/
Big bore throttle body
Pistons and compression ratios
- Forged vs. cast pictons
Connecting rods
Cylinder liners and sleeves
Crankshafts
Oil pumps
ARP head and main studs
Performance and low-compression head gaskets
High performance rod and main bearings
Performance surface treatments
- Low friction, oil dispersant, flow coatings
- Cryogenic treatment
Professional engine builders
Drivetrain Modifications
Clutches
http://www.newcelica.org/forums/showthread.php?t=208709
Flywheels
http://www.newcelica.org/forums/showthread.php?t=70710
- Flywheel bolt information
Limited-slip differentials (LSD)
- Clutch-type vs. helical
Short shifters
http://www.newcelica.org/forums/showthread.php?t=210641
Upgraded/strengthened transmissions
- Aftermarket gearsets
- Common transmission damage and part revisions
http://www.newcelica.org/forums/showthread.php?t=214602
http://www.newcelica.org/forums/showthread.php?t=192866
- 3S-GTE (E153) transmission conversion
Automatic transmission upgrades
http://www.newcelica.org/forums/showthread.php?t=101611
Performance/custom axles
http://www.newcelica.org/forums/showthread.php?t=214072
Engine mounts and urethane bushings
Shifter bushings and braided clutch lines
- Shifter base bushings
- Shift cable bushings
- Brainded stainless clutch lines
Engine control, electronics, gauges
ECU Tuning Forum
http://www.newcelica.org/forums/forumdisplay.php?f=208
A'PEXi Power FC
http://www.newcelica.org/forums/showthread.php?t=191180
http://www.newcelica.org/forums/showthread.php?t=187685
Greddy E-Manage/E-Manage Ultimate
Hydra EMS
http://www.newcelica.org/forums/showthread.php?t=212257
Power Enterprises CAMCON
http://www.newcelica.org/forums/showthread.php?t=213242
Split Second
AEM EMS
A'PEXi S-AFC/S-AFC II/V-AFC
http://www.newcelica.org/forums/showthread.php?t=113708
Dastek UNICHIP
http://www.newcelica.org/forums/showthread.php?t=54151
Jet Chip
http://www.newcelica.org/forums/showthread.php?t=96516
Venom 400
http://www.newcelica.org/forums/showthread.php?t=20630
OEM Toyota ECU
- Versions of ECU and part numbers
- Rev limiter conversion for 2002 model year GT-S
- Check Engine Light (CEL) codes and "resetting" the ECU
- ECU pinout for GT-S
- Learning function of ECU
Changing "lift" engagement point on 2ZZ-GE engines
Drive by wire (DBW) to cable throttle conversion
http://www.newcelica.org/forums/showthread.php?t=205309
Mechanical vs. Electrical gauges
Oil pressure and temperature gauges
Water temperature gauges
Wideband oxyegn (O2) sensors
http://www.newcelica.org/forums/showthread.php?t=188457
- Why air/fuel gauges are different than widebands and don't work
Exhaust gas temperature (EGT) gauges
Forced Induction: Turbochargers, Superchargers and Nitrous
Forced Induction & Nitrous Forum
http://www.newcelica.org/forums/forumdisplay.php?f=46
Turbo system FAQ
http://www.newcelica.org/forums/showthread.php?t=199226
Turbocharger kits
- C2 Power (C2) http://www.c2power.com/
http://www.newcelica.org/forums/showthread.php?t=211486
- Hass Pro Turbo http://www.hassturbo.com/
- XS Engineering http://www.xs-engineering.com/xsstore/pc/viewPrd.asp?idcategory=103&idproduct=634
- Stafford Fabrication (SF)
- ATR
- David Draper (DD)
DIY turbo systems
Turbocharger manufacturers
- Garrett http://www.turbobygarrett.com/
- Turbonetics http://www.turboneticsinc.com/
- HKS http://www.hksusa.com/
- Greddy http://www.greddy.com/
- IHI http://www.ihi-turbo.com/
Turbocharger distributors
- ATP http://www.atpturbo.com/
- Precision Turbo http://www.precisionturbo.net/
Wastegates and blow off valves (BOV)
- Differences between internal and external wastegates
Intercoolers
- Air-to-air
- Air-to-water
- Differences
Boost controllers
http://sportcompactcarweb.com/tech/0207scc_boost_control/
How much turbo boost is safe to run?
Cold air intakes on turbos
Supercharger kits
- Greddy
http://www.newcelica.org/forums/showthread.php?p=3513108
http://www.newcelica.org/forums/showthread.php?t=229926
- Blitz
DIY supercharger systems
http://www.newcelica.org/forums/showthread.php?t=167507
How do I raise the boost on a supercharger?
How much supercharger boost is safe to run?
Can I intercool my supercharger?
Is the Electric Supercharger legit?
Turbocharger vs. supercharger
Costs of forced induction systems
Spark plugs for forced induction
Clutches for forced induction
Boost gauges
Nitrous FAQ's and Install
http://www.newcelica.org/forums/showthread.php?t=42600
Nitrous kit manufacturers
- Nitrous Oxide Systems (NOS)
- Nitrous Express (NX)
- Zex
Nitrous system types
- Wet
- Dry
- Wet vs. dry
How much nitrous (shot) is safe to run?
Other Performance Topics
Suggestions for first time modders
http://www.newcelica.org/forums/showthread.php?t=128245
Weight reduction
- Guide to weight reduction
http://www.newcelica.org/forums/showthread.php?t=206358
- Lightweight wheels and wheel diameter
- What does weight reduction do?
Engine swaps
- 2ZZ-GE (GT-S) into Celica GT chassis
http://www.newcelica.org/forums/showthread.php?t=226223
- 3S-GTE swap (2nd Gen MR2 and 5th Gen Celica All-Trac)
http://www.newcelica.org/forums/showthread.php?t=187790
- Other engines
Drag racing
- 1/4 Mile Database
http://www.newcelica.org/other/tracktimes/index.php
- Setup and technique
Technical Topics
Repair & Maintenance Forum
http://www.newcelica.org/forums/forumdisplay.php?f=52
Celica Repair Manual - Toyota Big Green Book (BGB)
http://www.newcelica.org/other/technical/manuals/volume1.pdf
http://www.newcelica.org/other/technical/manuals/volume2.pdf
- Toyota Tech Info Website
Technical Service Bulletins (TSB) and maintenance schedules
http://www.newcelica.org/forums/forumdisplay.php?f=59
http://www.newcelica.org/forums/forumdisplay.php?f=60
General car specifications and maintenance schedules
http://www.newcelica.org/other/technical/specs/00.jpg
http://www.newcelica.org/other/technical/specs/01.jpg
http://www.newcelica.org/other/technical/specs/02.jpg
ASE papers on 2ZZ-GE engine
http://www.radphys.com/2zz_ge_article.pdf
VVTi and VVL systems
http://users.ameritech.net/trdcelica/VVT_Explanation.pdf
Basic fuel injection controls information
http://www.newcelica.org/forums/showthread.php?t=84901
Common acronyms and abbreviations
http://www.newcelica.org/forums/showthread.php?t=214876
Gasoline and octane number
http://www.newcelica.org/forums/showthread.php?t=197220
http://www.newcelica.org/forums/showthread.php?t=202049
Oils and gear lubes
Dynomometer (dyno) types
- Dynojet Model 248C
- Dynapack
- Mustang
- Dyno Dynamics
- Manufacturer engine dynos
How a dyno works/what it reads
http://sportcompactcarweb.com/tech/0011scc_sport_tuning/
Comparison of different dynos
Reviews of dynos and dyno shops
Bad/fake dyno information
http://www.newcelica.org/forums/showthread.php?t=206533
http://www.newcelica.org/forums/showthread.php?t=196242
The above list is a work in progress. If there are other topics you feel should be included, please post about them and the list can be edited. Any topic without a link needs one, so if you have appropriate threads, please post links to them.
Un-Registered User
yeah
1 - 15 of 15 Posts
