1 - 3 of 3 Posts
I changed the Trans fuild in my car today , mix MT90 with Mobil 1 Full synth and I noticed some cracks in the houseing . I know the houseing is cast i hear that it happends some times in other cars not cracking all the way though. Has anyone else had this problem ? I'll be takeing it in on saterday to have it looked at i've got 100K coverage.
take some pictures and post them...they might be just imperfections in the casting
When I had my trans out I noticed the same imperfections. At first glance they looked like cracks but they were only imperfections. If no gear oil is leaking out I would not worry about it.
FYI....I ground down the area where I thought it was cracked to an even surface. Then checked the area and there was no crack. If you are really concerned about it you can use a dye penetrant to check the area.
1 - 3 of 3 Posts
