1 - 9 of 9 Posts
Hi,
Does anyone here know how to remove the crankshaft pulley nut?
I need to remove in to be able to take off the timing belt cover.
Coz i need to pull off the top end for a spring, valve and cam swap.
By the way, the engine is out of the car and sitting on a pallet.
thanks.
Work Done, Sexy Time.
You really need an impact gun for this job. I'd just get one.
Discussion Starter #5
Can i buy a battery powered one?
Or i got to go the extra mile and buy an air compressor and the gun?
I've never used a battery powered one but that should work , I'd get the highest ft/lb one I could find, at least 300lb.
Discussion Starter #7
All good guys.
I did it with no impact gun.
I went down to my local auto car parts (Autobarn), and one guy there said to just remove the starter motor and then put a screwdriver inbetween the flywheel teeth, then slowly apply pressure to a 1/2 wrench with 19mm nut anti-clockwise.
I asked my brother to hold the flywheel with a smallish screwdriver and I turned the crankshaft nut anti-clockwise. It worked. Plus, I didnt need to use a harmonic balancer to remove the crankshaft pulley. I just pulled it right off with my hands - much easier than an alternator.
I have a pulley holder tool but the screw driver against the flywheel has worked in the past too when done carefully.
put the car in 5th or 6th gear, have someone else step on the brakes and crank on the bolt. it will come loose
1 - 9 of 9 Posts
