Hello guys, I have a 2003 GTS (EU model, known as T-Sport) and I'd like to install the stock cruise control because in Spain as far as I know it wasn't available as an option.
What do you think I need?
Thank you.
adding cruise to a car that didnt come with it is very difficult and expensive. yes it can be done and you will need all the parts you listed. you might have to add several wires to your harness.
Along with the actuator, you need the Cruise Control Computer, too. Not sure if this is the right p/n: 88240-20451 for you.
Discussion Starter · #5 · (Edited)
Well, in case of someone else has the same question as me... I can't install the stock one in my Celica because of the air injection system, it uses the space where the cruise control underhood actuator should be. The EUDM Celica has this system installed, I'll remove it someday.
