21 - 35 of 35 Posts
Tikked Again said:
It's not always oil that goes through the catch can, there's fuel and water vapor too :) Not something I would want draining back into my oil pan. Those crazy germans....
Can you explain this more in depth? I highly doubt that a mass-market vehicle manufacturer would put these on their product if it does this. I know that these plastic units are made by Purolator and also have an internal baffle. I really don't care about the *bling, bling* aspect of these oil catch cans, and would rather recirculate my oil anyway.
I have a small clear catch can. It usually fills up with a brownish liquid that looks and smells like a mixture of water and fuel and a bit of oil. Regardless if that is unique to my car, the oil that's usually in a catch can was once vapor. I doubt it's useful as a lubricant after being vaporized.
Hey MicaCeli
Nice write up!
I have to fit my Oil Catch Tank too. This makes it a bit easyer ;)
thanks for the write up. really helpfull!
Hi :burnout:
yesterday i have made this mod... but with another solution....
i have close the holes on intake manifold and Throttle body.
i have removed the pcv valve and replaced with free connection....
both tubes are in free draining.
what do you think about this mod?
P.S. I'm italian... exuse me fo my BAD english :sadpace:
Universal 9mm Inlet/Outlet
Universal 15mm Inlet/Outlet
which one is that ? from this mesures
and what does it due ?
do i need to put more oil in the engine
does that overstreess the engine some how ?
you said the you wont need to change the oil for 30 a 40 K what does tha means
sorry about the dum questions
thanks
I just read your install which was helpfull but, on my car i found oil in the other line that goes from the valve cover to the throttle body and in the throttle body. What is the purpose of the other line or should i install two catch cans?
The pictures seem to be dead. Could you maybe repost them so that i could have a better understanding of the install?
yeah pics are dead :(
I know this thread is quite old, can anyone update thread and put back all the jpgs because all the pictures are deleted and gone.:AF:
21 - 35 of 35 Posts
