1 - 7 of 7 Posts
Anybody know how to fix this or the part number? The wiring cut.
Safe to run like that?
54182
Sure get a connecror that matches that and either re pin it or get a wired pigtail and splice it in with solder(perfered) with heat shrink or butt connectors (heat shrink kind the hard plastic is garbage)
Safe to run. But, you'll get an EVAP CEL.
Remove the pins & see if you can reattach. The unused blue connector (due to using an SRI) could be cannibalized for parts. You might also be able to get a "service pigtail" for that connector p/n 82998–12440 & splice in.
54186
Discussion Starter #6
Hey also do you know why I can’t hear the lift crossover sound with my intake?
1 - 7 of 7 Posts
