Here is the sequence to follow:
You torque the cam bearing caps down little by little in several passes on each in the sequence shown. You never torque down one completely and then go to the next. Always do one a little, go to the next until eventually the cams are fully lowered into position and the caps are sitting snug. The torque spec is only 14 lbs, that's not a lot so don't overtighten them or you will strip the threads.
