1 - 20 of 33 Posts
Hey all, I finally got my car back from DA Sports. All I can say is Wow! I will do a full write up and get you dyno numbers as soon as I can get to a dyno. I will also get you pictures of the kit itself along with video if spidalegz helps me out. So till then, write up soon to come!!!!!!!!!!!
If anyone knows of a dyno shop in El Paso, TX or New Mexico let me know!!!!!!
Yes, I truly have the car. It is sitting at my house at this very moment. I have driven it from LA to NM and also upped the boost with the Greddy Profec B Spec II to 9.5psi. I have not had any problems thus far. I will definetly get you all updated pictures and a dyno as soon as I can find one near me.
jayloco is running this kit also, its been working for a few months now, it required massive custom work, but it works.
Originally posted by 2002Silver Celica
Let me know at what psi you all want the dyno set at. I don't have alot of funds, so I might be able to do like stock 5.5psi and maybe 8-9.5psi. So let me know!!!!!!!
That sounds good....
That is pretty good. However, I think that a most people with the SF kits hit 200-215whp at 6psi. But those are good numbers. Are you going to run 8.5 psi very often? 5.5 seema pretty low esspecially for a GT. Good job!
Discussion Starter · #19 ·
He is also running a bigger turbo with his kit. This is a KKK04 which is smaller than T3/T4 from SF.
1 - 20 of 33 Posts
