Damaged bumper
365 Views 6 Replies 3 Participants Last post by  gotya77
2
Someone is selling a 03+ front bumper, but it has some damage. I was wondering if it's worth it to buy and fix it, or if it will cost too much.
It also doesn't have a lip, can you buy this seperatly or does this always come with a bumper?
pics:
1 - 7 of 7 Posts
The lip can be bought seperately. I had my front lip replaced under warrenty.
If it is worth fixing that bumper would depend on how much you had to pay for the bumper and the cost of fixing it.
Yeah but what would be an estimate of fixing something like this and what did you pay for your lip?
lower cover cost
I am in the process of replacing the lower panel (lip).Lower cover itself about $45 + S&H. Make sure you order all the required nuts and bolts too. Its a fairly easy job to do at home.
The cheapest quote I have beena ble to locate:
https://www.parts.com/partlocator/i...2000&graphicID=8514005&callout=19&catalogid=2
They seem reliable. Got 2 batches of parts from them.
In your pics, I cannot see the details of the front bumper bottom. The lower cover (lip) is held to the front bumper a male/female coupling (cant find better words for this) and some grooves. The bottom of the lower cover would (Male / female coupling: a protrusion from the lower cover (lip) sits inside a slot in the bottom of the front bumper). If these slots in the front bumper is cracked / broken, it would not be stable.
You may want to check if you need to replace the under cover:
https://www.parts.com/partlocator/i...=2000&graphicID=8514030&callout=1&catalogid=2
Yeah I am going to check it tomorrow, also to pick up 1xOEM hid housing. Will see what the damage is and than see what I can do with it. I already got a pricequote for a lower lip which was $70. Which is more than I would pay for the bumper.
At the link you sent the numbers don't correspond correctly with the image shown, but I'll manage to figure it out.
Yes the indexing of the parts and the names dont match up.
Image : 18: Lower cover
Index: 19: Lower cover
Offset all the numbering in the image by 1.
1 - 7 of 7 Posts
