Anyone has the denso hid kit installed?
if so where did you put the ballast and how did you secure it????
coz it is thin and wide very awkward
thanks in advance pics would be fantastic
yea I like to know where people have been putting the ballast as well. is it water proof to wear its located?
If you are using the ballasts with the stock H7 headlamps, just tape them to the chassis right underneath the headlamp. Use, like mentioned above, 3M mounting tape.
If you are using the ballasts with the 03+ HID headlamps, they fit in the bottom of the housing and are covered/weatherproof in that location.
