QUOTE]
Originally posted by SpankinGT-S
How much does it cost to get the bungs welded? I am in the middle of this project also, and I already got my manifold. Also does anyone know where I can purchase the custom plumbing kit for a decent price? [/QUOTE]
bungs are definittly the way to go, since the walls of the tubes are so thin to tap. The cost to get a manifold done like Mine
http://www.newcelica.org/forums/showthread.php?s=&threadid=141112&highlight=direct+port+nitrous
would cost quite a bit . All work was done by myself and my boss so a price can not be deturmined . But you need to find some one VERY skilled in heleo arc welding to weld the bungs with No inconsistances.If it is not done perfect when the bungs start to be shaped , all inconsistances and voids will come out . You then need to find some one with a lathe and enuff patience to sit down and lathe out the bungs .A seperate Jig will also need to be custom made to set up the manifold in the lathe .The lathe time and messing around is whats really gonna cost ya .
Their is Quite a bit of time involved in what i just mentioned ,so that is Alot of Money right there. Exspeceilly if being charged an hourlly machinist rate $50 - $60 PLUS an HOUR.
Then after that it is still not done The base's of the bungs then need to be shaped in to the manifold runners, and the only way to do that is by hand . This Is COUNTLESS Hours, and the most time consuming. Thats gonna cost a Small fortune if any one else but yourself does it. if you Mess that up( do them uneven) or take too much off the bung , The Bung has to be rewelded and has to be redone .
After that it also has to be powder coated like mine or polished (even more $ LOL)
I hope this helps It is quite a project ,And I would hate to see What a machinist or shop would charge for the completed project,But Trust me Unless you have the hook up or a Freind Its gonna Cost Alot
Sinc:Kenny Heiser
