1 - 9 of 9 Posts
I know shops use computerized alignment/camber/toe adjustment that our manual hands could not compare to. But it's just that my steering wheel is off-center on straights. I also plan to put aftermarket 17s" next week. Should I just bring it to a shop to have them aligned, camber/toe adjusted? Or just adjust the steering wheel myself (is this even possible)?
If I bring em to the shop.. Do I tell them what values I want like how many degrees toe how many degrees camber? I don't know what's the ideal values for daily driving (No track setup).
umm you will just mess it up more by trying it by hand, if you have ever done and alignment on a laser rack you will understand. think of it as doing brain surgery with an axe.
can anyone recommend a good place to bring my car for alignment/camber/toe here in New Jersey? is SEARS auto a good one?
Also, Do they know what degree values to use? or they would ask me what i want?
they use factory spec. and thats what i would use.
i would avoid sears, go to a good tire shop or a big autobody shop.
12+ years daily driver
it is possible, but difficult. A LONG time ago (like 2003 or 2004) Import tuner did an article on how to do your own alignment. It was for a miata, but the principle is the same. It had you make precise sized boxes with tape under your wheels and told you how to measure the toe and such. You use a weight on a string to check for it being straight. It looks like a lot of work though.
If you are not lowered then just stick with the stock specs. I have had better luck out of small shops doing my alignments than these huge corporate franchises. Hope this helps you some.
I've seen a portible alignment machine in a magazine within the past year. i'll be damned if i can remember what, but it was featured for someone that would drive to a race and want to change ish, then change and drive back. It used the same type of head that would fit on a car but had air bubbles in tubes and such. it looked like it would get the job done, but nothing professional like putting it on a rack. you'd have to have it on perfectly flat ground too.
i might bring the car tom to a small shop in dover nj. it is a body shop though because i'll have them underwash the car and have it undercoated/rustproofed... at the same time i'll ask them who can they recommend for alignment.... do i have to do camber and toe? or just alignment?
camber and toe is the alignment, to straighten the steering wheel the change the toe of both wheels.
1 - 9 of 9 Posts
