You can buy camber bolts that replace the top bolt that holds strut to the knuckle...I did and have over 3 degrees of adjustment either way....theese cars love nwg camber...you can run 1.5-2.0 degrees negative all day long without bad tire wear...I personally run 2.3 degrees negative camber up front....they cost less than $50
