1 - 3 of 3 Posts
Hello, I am currently removing the old sway bar off my car and replacing it. As you can see by the picture the old one is done for XD. I was wondering do I need Hotchkis sway bar bushings and brackets? The old ones I have are rusted out and breaking apart. I have oem links but could not find anything on using oem bushings.
54295
The Hotchkis bushings are stiffer & the brackets have grease fittings. The OEMs are softer rubber bushings & no grease fittings.
I've seen some aftermarket ones with the grease fittings. Energy suspension is one good example. I guess all I would need to know is the right diameter for the sway bar and those should work? I looked at hotchkis website for new ones but cold not find them 😔
1 - 3 of 3 Posts
