So ever since I got this car (it was used) when the window on the driver side only is at anything less than fully rolled up, it rattles back and forth. It sounds like there is something that should hold it in place but it is missing. The window shakes back and forth very quickly making the rattle noise.
Any help is much appreciated!
While it's normal for it to shake a little, being a single carrier frameless design, it's not normal for it to rattle. You might want to remove the door trim and check for any loose guides or loose bolts on the carrier.
Yeah cause the other window doesn't do it at all and the driver window doesn't rattle a little, it is a lot. As if it is hitting both sides to bounce it back and forth.
I will open the panel then, thanks!
