Originally posted by migs
basically...dont gun it
know what rpm your turbo spools and dont go over it
:werd:Originally posted by WRENCHHEAD
kinda hard to explain.. driving the car normal like keeping the throttle partially open when excellerating, shifting at a lower rpm etc will keep the car in vacuum. basically the motor is running like it would stock where it's pulling in air on it's own.
putting the car into boost would be driving the car into.... say a freeway, you know how you mash the gas and shift at higher rpms to try and pick up speed, well when you put the motor under a certain amount of strain(load) the turbo will start to spool and in turn starts to fill in the vacuum in the intake track with positive air pressure, meaning it's pushing air into the motor vs. the motor pulling in it's own air.
Well, a stock 125 torque GT breaks loose EASY in snow, it would be the boost spikes that would send you losing traction.Originally posted by IScrewedUp
Lowering your PSI wouldnt help?
its light weight. You will need GREAT snow tires. But anycar will lose traction in the snow. Just drive properly. That is all.Originally posted by IScrewedUp
How does it break loose easy in the snow . I thought the torque on all celicas was high end , not lowend?
IScrewedUp said:i figured it would be hard to break traction with it being fwd in the first place.
A FWD car will break traction easily. As a matter of fact easiest.Originally posted by IScrewedUp
Originally posted by JohnnyWash1
You are on the right path, but you need to take the next step. Initial traction is very good on front drive cars, because of the high weight being over the drive wheels. However, once the vehicle starts accelerating, that weight gets transferred to the rear (which is exactly what gives rear-engined Porsche 911s their great traction). With the weight transferred to the back, your front end will lose traction.
Also, lowering the PSI might help some, but any boost at all will be bad in the snow, so staying off the throttle is key.
Jon
NoRulzAt140 Mph said:A FWD car will break traction easily. As a matter of fact easiest.
The weight is only over the front drive wheels before you actually move. Unless you take purposely take 20 seconds to 30 MPH in the snow.
:gap: I dont get you manOriginally posted by JohnnyWash1
You quoted me, so I assumed you read my post. Thanks for the echo post, however.
