Not the 00+ Celica.Originally posted by icyhotgts
Don't think it matters, most cars automatically disables a/c in WOT.
Originally posted by JohnnyWash1
That's why you keep it on recirculate, so the A/C doesn't use power all the time.
cool2miketlu said:hmmmm correct me if I am wrong...
AC running meaning engine gets hot, I noticed the engine runs the best when the ECU reads 188 degrees when I dyno tuned. Which one would reasonably assume it would run real bad because of all the heat the AC caused. Unless maybe the AC is somehow directed to intake so engine get cold air, but then the heat caused to by running the AC would negate that cold air.
I believe that was something in the prototype Lightning and it used the A/C system to chill the intercooler. They called it something akin to a 50 shot of nitrous that you never have to refill.JohnnyWash1 said:There is a system that just came out for a Ford Truck? or some other domestic vehicle called the supercooler or some other such nonsense, which actually uses the A/C compressor to route cooler air to the supercharger (I think it was F/I--which was what made the loss worth the gain). I'll have to do more research.
Blue--A while back I learned that on the "max" AC setting or recirculating AC setting on most cars the compressor does not run all the time, because the chilled air is recirculated.
Jon
thats pretty nice. no the stock ecu doesnt do thatIllusive said:with the pfc it shuts off the a/c when you go wot
you can tell because if you stay wot the air that is blown out the vents gets hot a few seconds later,
then it cools back down once you let off wot.
stock ecu never did that that I can remember
The temp probe is set to go off near freezing. It's attached to the AC unit, so I would assume its to keep it from icing up.Originally posted by lhowing884
yea notice how the a/c goes on and off once the temp inside is steady at a caertain temp. if you dont believe me, yank open the evaporator and youll see a temperature probe after it.
Wow, that's pretty cool. If there's nothing cheaper on the market that does the same thing, I'll probably pick that up next summer and see if it works on our cars.Originally posted by spookie
Maybe this could be interesting for people that use the AC a lot: http://www.zeitronix.com/tcac/tcac.htm
BR
Originally posted by toxcity
I was just wondering if anyone has done a dyno run on a stock celica with the a/c on. I've just always wondered how much HP you lose with it on.
