I have an 05 GTS 6mt which means my lift is engaged fairly late at 6500rpm. I recently found out the 03 GTS has lift at 6200rpm and the same limiter as the 05. as far as I can see theres no major differences apart from the lift engagement. I am pretty sure the 03 has the same emissions and air injection setup as the 05, as well as drive by wire... not seeing any differences, and am confused why nobody has done this, people always talk about swapping the 02 ECU with ECU's from a 00 or 01 car, wondering why this can or cannot be done.
