Well my check engine light came on a while back when my car started auto revving and idling at 2000, then dropping to 600rpm. I took it to the shop had them to a quick fix on it. Now it idles at 1100rpm.
Before my car had problems it would start at 1000rpm (when i started the car) and once it was running for a good 5 minutes the idle would go down to 700rpm and stay there. It used to always idle at 700rpm with no problem now even after driving the car for a while it stays between 1100 and 1000rpm. Is there anything wrong with this?
(before when it would go from 2000rpm to 600rpm it felt like if it dropped any lower than 600rpm the engine would cut off, 700rpm is a fine idle for me and has always been that way since i got the car in 03')
