1 - 14 of 14 Posts
Hi guys,
so in short, I am removing my engine due to spun bearing, using the guides here and help from some experienced motorheads from local celica club.
Im wondering what are your thoughts about this ebay engine rebuild kit?
http://www.ebay.com/itm/00-06-Toyota-Celica-Corolla-1-8L-VVTL-i-Master-Overhaul-Engine-Rebuild-Kit-2ZZGE-/281206124822?pt=Motors_Car_Truck_Parts_Accessories&fits=Year:2000|Model:Celica&hash=item417930f116&vxp=mtr
looks OK, but im concearned about the gasket quality
Kit includes :
Multi-Layered Steel head gasket
Intake manifold gasket
Exhaust manifold gasket
Valve cover gasket
Viton valve stem seals
Camshaft front
O-rings
Front Seal Gasket
Rear Seal Gasket
Water Pump Gasket
Timing Cover Gasket
Other Small Gaskets
4 Pistons (Available in Standard and Oversizes: .50mm = .020")
Complete Ring Set for 4 Pistons (Available in Standard and Oversizes: .50mm = .020")
Wrist Pins and clips
Compression Ratio: Stock
Bore Diameter: 82.00 mm
1st Group: 1.20 mm
2nd Group: 1.20 mm
Oil Ring: 3.00 mm
Complete Main and Rod Bearings
Main Bearing Set (Standard or Oversize: .25mm = .010" or .50mm = .020")
Rod Bearing Set (Standard or Oversize: .25mm = .010" or .50mm = .020")
Trust Washers
Oil Pump
Water Pump
Timing Chain Kit
1 Timing Chain (136 links)
1 VVT-i Sprocket (intake)
1 Cam Sprocket (exhaust)
1 Crank Sprocket (18 teeth)
1 Guide Rail (left - fixed)
1 Guide Rail (right - tensioner arm)
1 Tensioner (ratcheting style)
This timing kit is for high output engines, and does not fit for CELICA GT model.
10 Head Bolts
do NOT use ebay rebuild kits. they are SHIT!
get the OEM kit from the dealer. yes its more expensive, but do you want to do all that work all over again?
Crap...
Well quality = money...
but is there anything aftermarket, that might be used and is in similar price as oem?
Just out of curiosity, have you ever personally seen these kits or used them in a rebuild? Just curious to know what exactly is crap about them. Not debating their quality, just wanted to know what makes them inferior.
I'd be wary of any ebay 2ZZ kit that offers oversize pistons. :ugh:
Discussion Starter #6
Well the pistons and rings on the ebay set seem to be from NPR. And NPR looks reliable, based on the info i can find...
the 2ZZ is very picky, I would only use OEM pistons too.
yes I have seen the Fel-pro and some other kits. the gaskets are not near as thick. take the timing cover for example. that gasket wasnt thick enough to make a good seal. It would have leaked. same with the water pump seal. After that, OEM only! they just work and I dont like doing things more than once.
so do it right the first time OEM!
^^^ This, you don't want to skimp on stuff like this. Doing things over will cause you more money and headache later.
I have seen plenty of Toyota's with over 300k on the odometer come through various service drives. You want to know why they still run like a champ?
Owners only used OEM parts.
Discussion Starter #9
Well OEM parts it is then...
This means ill have to overhaul the engine and stay without my celica for a longer time, because of tight budget. But keeping it running in longer term is more important I guess.. Its my money eating baby :love:
Lift is a beautiful thing
I used an eBay gasket kit to rebuild my last motor. The head gasket blew out after a couple weeks which led to engine failure. I have learned the hard way
I used that kit from monkeywrench on my race car engine rebuild and have no complaints so far.
Dentman
Spanning Tree Storm
MWR is OEM. just search for the part number. I have received mine few days ago
1 - 14 of 14 Posts
