1 - 20 of 35 Posts
did u feel a big difference with the rear put in? i'm still deciding whether to put this in after hearing about some guys celica breaking down from putting in c-one motor mounts, i guess it caused shock to his tranny
well i installed both front and rear at the same time.
the engine feels very firm in its place. acceleration feels a bit more direct than before. other than that everything is fine. a bit of vibration at idle but non of that bothers me.
are the c-one motor mounts solid metal mounts, when i checked they had front rear and sides not sure though.
nice guide...i have yet to do my rear ones...thanks!
what you can do it paint my JDM console CB like yours, that would be spectacular...
i think im doing this install tomorrow :)
Can you do a good job?? Like urs...
-also i could not for the life of me break that bolt on the mount. I felt like my damn 6 extensions were going ot snap, they were all torquing at the connections, instead of torquing the bolt...so i gave up...
damnit
Discussion Starter #9
i would probably do a better job on someone elses car
my car is my guinea pig, i wouldnt do something to another car unless i were sure i could do it.
let me know if your intrested ;)
its in the write up but
i used two extensions one 20inches the other 10 inches and a half inch drive breaker bar
worked like a charm
i didnt even use any liquid wrench on it although i would recomend it.
No see, i dont have extensions that long, i had to use like 5 6inch extensions...so it made a lot of weak point when i started to torque it...
i suppose thats what ill be buying next!
1 - 20 of 35 Posts
