21 - 38 of 38 Posts
I saw in the picture that there was a red wire going from one point to another, is that a modification? or is it like that already? Do I need to do that also? Or do I just swap the mosfet transistor? I really want to get this fixed as soon as I possible can so I can enjoy my new blue led's!!!
also, does anyone have any spare transistors left over???? i see that digikey doesn't seem to have any in stock, and I have no idea where else to get one. If anyone knows where to find them please let me know!!!!!
The red wire had been added to ground the lights on high because of the failed transistor. It was removed when the transistor was replaced.
well thats good to hear, so the additional grounding isn't necessary after the transistor has been replaced eh? because I don't want to chance it happening again.
If you don't use the transistor, you can just use the red wire to by pass it..
It's gona work, but you'll loose the dimmer funcion....
I really want my dimming function, since I just finally got it wired into my stereo last week, im really enjoying it now, lol. I'm waiting on pm from 2way about the transistors, because I think he's one of the few places I can get one from. Hopefully he replies quickly, because I want that transistor as soon as I can get it!!
Probably what blew it. The dimming on the Celica is the reverse of what most HU's require. Most HU's want varying +12V. The Celica varies the path to GND.
2way, you've got payment!
just got my transistor in from 2way and got it soldered in. re-installed the gauge cluster and still have the same problem i had before. none of my hvac lights/hazard/cig lighter light up still. Although my gauges have regained their full dimming capability, I am at a loss for the rest of the problem. If anyone has any idea what my problem might be please let me know.....
i mean if my dimming works, then nothing could have went wrong with the replacing of the transistor could it? Is it possible that the tab isn't down well enough and its not grounding solidly? I just am trying to think of any explanation for why I am the exception to this fix..... please help
You probably still have the original problem on the outboard dimming circuit that blew the transistor in the 1st place.
then that must mean that the original problem is that my headunit has the white/green dimming wire spliced into the orange illumination wires in my aftermarket wiring harness. if I detach the white/green wire from the orange ones, should that fix the problem? or have I already burnt the brand new transistor you just sent me? good god i hope thats not the case.... would there be any real way to tell if it was burnt?
well i just detached the dimming wire from the head unit, and it didnt affect anything. now im worried i already burned out my new transistor. although my gauge dimming still works, so i think that means i didnt burn it our right? really running out of ideas here...
i'm wondering if running the red wire would provide the "solution" for my console lights problem. at this point i would give up my dimming for my lights to just work. i realy want to see my new LED's in action, but im not going to install them until this is fixed....
ran the red wire today, all lights functioning again, and the dimming to my gauges still works. Thank god.... now all i need to do is put in my new blue LED's!!
thanks 2way worked for me 2011 rav4
feel like i should make a donation
your work saved me a lot of cash and headache
:thumbup:
21 - 38 of 38 Posts
