1 - 3 of 3 Posts
I installed my Shifter yesterday and when I move the shifter over as if I am going to go into 5th ( i dirve a GTS) the shifter will just kind of sit there if I move it to the left it will spring back, did I do something wrong ?
Did you install the shifter base bushings? If so, did you install them correctly?
They should raise the shifter base about 1/4" inch.
Erik Johnson
yea I figured it out , the bash bushings are cuaseing it to sit higher so everything is just fine I just didn't put everything together in my mind about how if you raise it up it will change where how it will feel. great shifter by the way its not bad for 52.00 shipped.
1 - 3 of 3 Posts
