2002 GTS USDM
Hello.
Long time lurker, first time poster here.
I would like to share my experience of installing Megasquirt (MS3Pro) on my 2002 Celica GTS.
Hardest part was making a dual-ECU wiring harness and a waterproof ECU box.
I also made a rough basemap, but it wasn't that hard.
As a base for my wiring splitter, I took the motor harness extension and the wiring that came with the MS3Pro.
54956
Waterproof dual ecu box
54957
Additional water temp sensor for Megasquirt
54958
Video of a running engine and TunerStudio dashboard connected via Wi-Fi
I've made a blog post with more detailed information, wiring connection tables and basemap.
Installing MS3Pro on 2ZZ-GE Toyota Celica 2002
(If posting links is not allowed, I can repost all information here)
Bring on the 12's...
Very very nice work, well done.
Does it allow you to control VVL and VVT like a Power FC? Does it have knock detection and retard built in?
2002 GTS USDM
Thanks!
Yes, MS3pro supports all of this.
Still need to tweak my map for proper smooth VVT control.
VVL is very simple on-off and works great.
Knock detection works with a 2-wire knock sensor. Not sure about the early 1-wire knock sensor.
I have to ask.....will you be offering this plug/play harness to the community to buy?
2002 GTS USDM
Unfortunately, I don't have time for this because of my main job.
But if someone else wants to build a kit based on my design, I don't mind.
