1 - 7 of 7 Posts
Does anyone have an image.. or can describe to me where I can pass wires though the firewall at?? Thanks in advance.
i just read the answer to your post in another thread in the audio, electrical, and security forum just a few minutes ago... you need to look for where the ecu wiring harness goes through (there should be a rubber grommet)... on my car under the hood it is behind and just to the left (towards the center of the car) of the battery...
hope this helps!!!
peace
Using the instruction for installing the Toyota VIP RS3200 Toyota alarm,we can use the wire-routing method described for running #4AWG or #8AWG wire for an aftermarket audio setup......this works slick as hell and no drilling is required!
Here is what you need to do:
* FOLLOW STEP #2 AND STEP #3 ON THIS PAGE:
Now that you have the outside and inside access to the grommet,
* THEN FOLLOW STEP #3 AND #5 (fig B3) ON THIS PAGE:
Your wires WILL fit in the little hole that is created when you cut off that little nipple from the grommet!
I pulled them though somewhere else...I pulled them like 3 inches above the gas petal
Here ya go
After I ran the wire through I covered it with a plastic hose cover to protect the wire from heat.
It's much easyer to start from inside the car and run runwire to battery
Easier to just run wires up side of the dash by the A pillar and tuck them through where the fender meets the windshield. Then run them under the bottom windshield plastic into the engine bay.
i have a 0/1 guage, and it DOES NOT fit with the ECU wires
i just ran it under the car, tucked it under the wheelwell and brought her through the crease right before the door
1 - 7 of 7 Posts
