I found a spot just above the gas pedal, it have bunch of wires going thru. But where do that end up in the engine bay?
I also found a spot on the left side of the battery, but that spot seem it will go into the dash, so how am I gonna feed the wire thru and get the on the other side?
i think people havent been responding because basically they have nothing nice to say for the newb question.
that hole you see behind the battery is the firewall that will lead to the hole above the gas pedal. get a wire hanger or something that you can fish a wire through with. if you cant manage to do that yourself, ask someone else :)
this little plastic peice is on basically on all cars. Its the most favorable spot to run a positive wire from the battery to a amp. Im not sure if the master cylinder is near there.
