1 - 2 of 2 Posts
Hi guys, is there a guide on how to fit a aftermarket Sparco steering wheel to my Gen 7?
I have the correct Momo boss kit and resistor cable for the airbag light.
Only guide I can find is one for a quick release boss, mine isn’t a quick release so could really do with a guide if possible.
Thanks
fbJapTengoku-577561959080
Disconnect your battery
x2 hex screws either side of the airbag remove them
Think a 19mm socket that holds the wheel to the coloum. Make sure your wheel/wheels are straight before removing wheel.
Before moving wheel completely leave the 19mm bolt a few threads on as when you remove the wheel you may have to tug at it a few times and you don't want to smack yourself in the face with it. When wheel is off, stick on your boss kit there may be a little up arrow on it indicating it should be placed at 12 o'clock tighten the 19mm nut back on but dont over tighten it you may crack your boss kit if you over tighten it. connect everything back on and bring car for spin. recheck 19mm that its tight
1 - 2 of 2 Posts
