1 - 2 of 2 Posts
How many fuses are for the front fog lights? I checked the main one and it is fine. My problem is, they won't turn on at all and the bulbs are fine. What could be the problem? Before this problem my foglights wouldn't turn on if my high beams were on, but when the low beams are on they would turn on. What is up with that?
The fog lights are supposed to turn off when the high beams are on. The fog lights require the low beams to be on.
Relay F12, in the driver's side kick panel, is energized when the low beams are on AND the fog switch is on. It requires both the 10A HEAD RH LWR fuse, in the Engine Room Junction Block and the 15A FR FOG fuse, in the Instrument Panel Junction Block.
1 - 2 of 2 Posts
