1 - 3 of 3 Posts
Originally posted by Celikazam
How do you change the bulb of the stock foglights?
The easiest way is to pull off your front bumper, then remove the two bolts that hold the fog lights in place. You should be able to complete the job in about 20 minutes. If you are used to taking your bumper off, you can finish it in about 10 minutes.
1 - 3 of 3 Posts
