ive been trying to save for my j spec 3 sgte,but im in a lil bit of a bind so ive been pondering just building the 2zz.What did you guys do about the tranny.Does anyone make a stronger tranny..one peferably that still retains a cruising gear
Mines on the way...1-4 are straight gears and 5th and 6th are normalOriginally posted by My Sixth Gear
c2gas
That's going to be loud.Originally posted by Smaay
5th gear yes, 6th gear is made even longer for F/I applications. C2Power stage 2 takes us to a max speed of 270km/ph. Even more with the new tranny.Originally posted by My Sixth Gear
so 5th and 6th are just like the stock tranny?
I think stock GT-S tranny will surpass 270kmph before fuel cutoff. A Celica have no business doing that fast anyways. You probably need at least 400+ hp to reach that speed. What's the point?Bing said:5th gear yes, 6th gear is made even longer for F/I applications. C2Power stage 2 takes us to a max speed of 270km/ph. Even more with the new tranny.
Nah - unless the C2 Stage 2 is 400 HP (which I don't think it is, not to the tire anyways)nyoneway said:I think stock GT-S tranny will surpass 270kmph before fuel cutoff. A Celica have no business doing that fast anyways. You probably need at least 400+ hp to reach that speed. What's the point?
Yes, since the GT redlines at 6800rpm and the GT-S redlines at 8300.... sure it will go even faster.Originally posted by nyoneway
Yes it will. Gas mileage improves if you use the 6th gear(due to lower rpm at same speed).Originally posted by X-EVIL-X
would that improve gas mileage also?
need 400+ hp to go 140mph?nyoneway said:I think stock GT-S tranny will surpass 270kmph before fuel cutoff. A Celica have no business doing that fast anyways. You probably need at least 400+ hp to reach that speed. What's the point?
wELL YOU DONT NEED 400+ HP>nyoneway said:I think stock GT-S tranny will surpass 270kmph before fuel cutoff. A Celica have no business doing that fast anyways. You probably need at least 400+ hp to reach that speed. What's the point?
Actually its not loud at all. 6th has a slight wiring (sp)to it, but its a cool sounding noise.Originally posted by WillyK
Well I dont think I have 400hp but ive reached 250kph with the tranny and only stopped because of the tires. Ok yea and a dip in the autobahn made me think about what i was doingOriginally posted by nyoneway
Boosted2.0 said:Nah - unless the C2 Stage 2 is 400 HP (which I don't think it is, not to the tire anyways)
I know- I was just saying that you guys hit that mark with well under 400 hp is all.C2til said:The euro spec GT whit the stock 6pseed has a very long econo 6th speed! The stock car hits max speed at 5th gear!
When you give the car some well diserved boost, you can hit rev limiter in 6th, and that is allready off the scale on the speedo! That is whit a 250+hp GT.
Give another 100hp that soceur's car has and EVEN LONGER gears...and you are asking for the best tires money can buy, because top speed will be shadowing everything but the best porpouse built highway rockets that are tuned, and has unlocked speed limiter. Not wise on stock tires, and suspension...but soceur has a well planed coilovers, but ****ty tires..... yet!
Watch out for more :-D
Well under is relative. Most ppl know that Gt can make 280-300 whp at 14,7 psi (mine does ~285) where you add 20% and get ~350hp at crank.Boosted2.0 said:I know- I was just saying that you guys hit that mark with well under 400 hp is all.
