1 - 7 of 7 Posts
I changed my ground wire to 0/1 gauge. Thats it.
You didn't change the other 2 wires (alt - batt, alt - ground)? What kind of system do you have now? Do you get dimming?
i forgot about connections between alt and battery. I figure I'm running completely off the alternator anyway. I only have some dimming when I crank it all the way up.
You would be wise to upgrade your wires to at least 4-gauge. The grounding wires/strips as well as your alternator wire.
Curt
I added aux. sealed 850/amp battery to the rear fed by #2 ga. wire. one 1 farad
& 1 1/2 farad cap. Its running one PPI
21400 & one PPI 2600. With the 21400
powering 2 punch RFR 3110 rms @ 1000/w . The 2600 is powering a set of
MB Quart PSD 316s . no light dimming at all .
1 - 7 of 7 Posts
