1 - 4 of 4 Posts
I found an old set of keys in the house. The keyless entry remots is missing and I have a nagging feeling a copy of the car key might have been made. How hard is it to change the keyless and the locks on my car? I have an alarm to be installed, would they be able to use that instead of the stock remote and disable the stock remote system?
yes if u open the door with the right key then the alarm will disable itself
No I mean make it so the stock remotes dont work at all. Then patch in the 2way alarm to activate the remote door openers
Yes, but a key will still get them in... & depending on alarm... may allow them to shut it off.
If it's only the remotes you're missing... I forget how many the factory module will accept... but you can program the old ones out with the replacements.
1 - 4 of 4 Posts
